Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Remove the rubber O-rings from the antenna jack, volume switch, and channel switch. Once the rubber O-rings have been removed, use small needle nose pliers to unscrew the nuts on the antenna jack, volume switch, and channel switch. There are washers underneath the nuts on the antenna jack, volume switch, and channel switch. Set these washers aside.
Antenna, Volume, Channel Nuts
  • Remove the rubber O-rings from the antenna jack, volume switch, and channel switch.
  • Once the rubber O-rings have been removed, use small needle nose pliers to unscrew the nuts on the antenna jack, volume switch, and channel switch.
  • There are washers underneath the nuts on the antenna jack, volume switch, and channel switch. Set these washers aside.
Hier Übersetzung einfügen
