Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Remove the two 2.8mm silver Phillips screws on the sides of the frame. The two 2.8mm screws are on each side of the device. Insert a plastic prying tool between the bottom of the case and the motherboard.
  • Remove the two 2.8mm silver Phillips screws on the sides of the frame.
  • The two 2.8mm screws are on each side of the device.
  • Insert a plastic prying tool between the bottom of the case and the motherboard.
  • Pry up the assembly and lift it away from the case.
Hier Übersetzung einfügen
