Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 19 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 4 übersetzen
Schritt 4
Carefully lift the lower casing from its bottom edge. The lower case is still attached to the motherboard by the volume and SD board cable highlighted in red. Do not try to completely remove the lower case of the DSi yet.
  • Carefully lift the lower casing from its bottom edge.
  • The lower case is still attached to the motherboard by the volume and SD board cable highlighted in red. Do not try to completely remove the lower case of the DSi yet.
  • Pry the volume and SD board cable up from its socket on the motherboard using a spudger.
  • Once the cable is completely removed, then you may take off the entire outer casing.
Hier Übersetzung einfügen
