Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Using the spudger, create space between the speaker covers and then remove. On the underside of the device, remove the rubber stand with the BeatsPill logo on it. Using a Philips #0 Screwdriver that is ESD-safe. Remove the 4 screws circled in blue that were underneath the rubber stand.
Removing the Case Screws
  • Using the spudger, create space between the speaker covers and then remove.
  • On the underside of the device, remove the rubber stand with the BeatsPill logo on it.
  • Using a Philips #0 Screwdriver that is ESD-safe. Remove the 4 screws circled in blue that were underneath the rubber stand.
Entferne den Gummifuß von der Unterseite des Gerätes. Drehe die sechs Kreuzschlitzschrauben #00 darunter heraus. Zwei Schrauben haben 6,97 mm Länge, vier am Gehäuse 9,11 mm.
Entferne den Lautsprecher mit dem Kunstoffwerkzeug.
Entferne die Schrauben auf der Rückseite des Gerätes.
[title] Removing the Case Screws
[* red] Remove rubber stand fromUsing the lower portionspudger, create space between the speaker covers and then remove.
[* orange] On the underside
of the device. Use a phillips head screw driver, size (PH00 or PH0) todevice, remove the six screws located under the rubber stand. The two band screws being 6.97 mm and four case screws being 9.11 mm in length.
[* red] Use
stand with the rubber tool to remove the speakerBeatsPill logo on it.
[* light_blue]yellow] Using a Philips #0 Screwdriver that is ESD-safe. Remove the 4 screws oncircled in blue that were underneath the back of the pillrubber stand.
[* red] Use
