Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
2. Schritt
Remove the 2 screws circled in red with the  ESD-safe Philips #0 Screwdriver. Slowly remove the center band and 2 clip rings until the adhesive seperates as to prevent damage. Slowly remove the center band and 2 clip rings until the adhesive seperates as to prevent damage.
Removing Center Cover
  • Remove the 2 screws circled in red with the ESD-safe Philips #0 Screwdriver.
  • Slowly remove the center band and 2 clip rings until the adhesive seperates as to prevent damage.
Heble unter der Verklebung und entferne die Hauptabdeckung. Entferne dann die Kunstoffklammern um das Mittelband.
Entferne die Schrauben auf der Unterseite.
[title] Removing Center Cover
[* bluered] Remove center cover by prying underneath the seal. Note: (use care due to adhesive located underneath). Then2 screws circled in red with the ESD-safe Philips #0 Screwdriver.
[* orange] Slowly
remove plasticthe center band and 2 clip rings around the center band.
[* red] Remove
until the adhesive seperates as to screws under the pillprevent damage.
[* orange] Slowly
[* red] Remove
