Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
3. Schritt
Using the spudger, starting in the middle, pry the device apart along it’s seam as circled in pink. Open the device as highlighted in red to separate the two main bodies of the device. Device should look as picture above. Open the device as highlighted in red to separate the two main bodies of the device. Device should look as picture above.
Separate the Device
  • Using the spudger, starting in the middle, pry the device apart along it’s seam as circled in pink.
  • Open the device as highlighted in red to separate the two main bodies of the device. Device should look as picture above.
Heble die obere Hälfte vom Rest des Gerätes ab.
Setze das Werkzeug zwischen den Gehäuseteilen ein.
[title] Separate the Device
[* red] PryUsing the top half ofspudger, starting in the middle, pry the device fromapart along it’s seam as circled in pink.
[* orange] Open
the center crevicedevice as highlighted in red to revealseparate the inner circuits.
[* violet] Use your tool to get the middle
two main bodies of the pill to opendevice. Device should look as picture above.
[* orange] Open
