Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
4. Schritt
Circled in red is the speaker pin (yellow, red, black, white) from the mother board.    •    (Caution! Ground yourself when touching the mother board) Take a picture of the device cables connected to ensure you’re able to reconnect them correctly later. Circled in red is the speaker pin (yellow, red, black, white) from the mother board.    •    (Caution! Ground yourself when touching the mother board) Take a picture of the device cables connected to ensure you’re able to reconnect them correctly later.
Disconnect Speaker Wiring
  • Circled in red is the speaker pin (yellow, red, black, white) from the mother board. • (Caution! Ground yourself when touching the mother board) Take a picture of the device cables connected to ensure you’re able to reconnect them correctly later.
Ziehe den Stecker mit den Lautsprecheranschlüssen (gelb, rot, schwarz, weiß) von der Hauptplatine ab. Benutze ein Erdungsarmband, wenn du die Hauptplatine anfasst. Notiere dir, wo welches Kabel hin gehört.
[title] Disconnect Speaker Wiring
[* red] RemoveCircled in red is the speaker pinspin (yellow, red, black, white) from the mother board. Note: (Be sure to use caution and ground • (Caution! Ground yourself when touching the motherboard) No particular wire disassembly order needed, just be suremother board) Take a picture of the device cables connected to write down where each wire pin was unplugged fromensure you’re able to reconnect them correctly later.
