Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
5. Schritt
Circled in red here is the NFC sensor cable. This cable has two (black and red) wires and should be removed carefully. Circled in red here is the NFC sensor cable. This cable has two (black and red) wires and should be removed carefully.
Disconnect NFC Sensor Wiring
  • Circled in red here is the NFC sensor cable. This cable has two (black and red) wires and should be removed carefully.
Löse den Anschluss nahe der "b" Marke. Er hat ein rotes und ein schwarzes Kabel.
[title] Disconnect NFC Sensor Wiring
[* red] Remove theCircled in red "b" button connectorhere is the NFC sensor cable. This connector containscable has two wires, a red(black and red) wires and black wireshould be removed carefully.
