Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 6 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 6 übersetzen
Step 6
Starting at the red rings along the hinge, insert a spudger or plastic opening tool into the seam between the two halves of the case. Slide the spudger toward the front of the device, releasing the small clips that hold down the top case.
  • Starting at the red rings along the hinge, insert a spudger or plastic opening tool into the seam between the two halves of the case.
  • Slide the spudger toward the front of the device, releasing the small clips that hold down the top case.
  • Gently lift off the top case.
Hier Übersetzung einfügen
