Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
3. Schritt
Gently slide the circuit board out away from the port connections. Pull it toward where the lens used to be. Some wiggling may be necessary to remove. The circuit board is fitted into slots attached to the side of the camera. Do not angle upwards to remove.
  • Gently slide the circuit board out away from the port connections. Pull it toward where the lens used to be. Some wiggling may be necessary to remove.
  • The circuit board is fitted into slots attached to the side of the camera. Do not angle upwards to remove.
Hier Übersetzung einfügen
