Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 52 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
18. Schritt
Insert a new opening pick and slide it to the middle of the right edge of the iPad, releasing the adhesive as you go. The display cables are located approximately halfway from the bottom of the iPad. Stop sliding the pick when you get ~4.5" from the bottom of the iPad. The display cables are located approximately halfway from the bottom of the iPad. Stop sliding the pick when you get ~4.5" from the bottom of the iPad.
  • Insert a new opening pick and slide it to the middle of the right edge of the iPad, releasing the adhesive as you go.
  • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding the pick when you get ~4.5" from the bottom of the iPad.
Führe einen neuen Opening Pick in das iPad ein und schiebe ihn in die Mitte der rechten Kante des iPads, um den Kleber der Kante entlang zu lösen.
Die Display-Kabel befinden sich etwa auf halbem Weg von der Unterseite des iPads. Stoppe mit dem Opening Pick, wenn du dich ca. 11 cm von der Unterseite des iPads entfernt befindest.
[* black] Insert a new opening pick and slide it to the middle of the right edge of the iPad, releasing the adhesive as you go.
[* icon_caution] [guide|88071|Thehttps://d3nevzfk7ii3be.cloudfront.net/igi/lwAVndGwbUvVYSmI.large|The display cables|stepid=62527|new_window=truecables|new_window=true] are located approximately halfway from the bottom of the iPad. Stop sliding the pick when you get ~4.5" from the bottom of the iPad.
