Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2 übersetzen
2. Schritt
Tilt top casing up and towards you. Carefully remove the right ribbon-wire from the top camera panel by pulling where the wire connects to the top. Make sure to hold the camera with your thumb on the white square to ensure the ribbon-wire is not disconnected from the motherboard.
  • Tilt top casing up and towards you.
  • Carefully remove the right ribbon-wire from the top camera panel by pulling where the wire connects to the top.
  • Make sure to hold the camera with your thumb on the white square to ensure the ribbon-wire is not disconnected from the motherboard.
  • Carefully remove the left ribbon-wire from the top camera panel by pulling where the wire connects to the top.
Hier Übersetzung einfügen
