Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diese beinhalten.
Englisch
Deutsch
10. Schritt
The LCD needs to be removed to proceed. Start by disconnecting the marked cable from its socket and disconnecting the cables from their clips in the palm rest. Proceed to  pull the two WiFi antenna cables through the motherboard. Remove the screws that hold each LCD hinge cover in place. There is 1 screw for each cover.
  • The LCD needs to be removed to proceed. Start by disconnecting the marked cable from its socket and disconnecting the cables from their clips in the palm rest.
  • Proceed to pull the two WiFi antenna cables through the motherboard.
  • Remove the screws that hold each LCD hinge cover in place. There is 1 screw for each cover.
  • Gently pry each cover off its hinge.
Hier Übersetzung einfügen
