Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diese beinhalten.
Englisch
Deutsch
13. Schritt
You will need to remove the bezel under the LCD hinge to finally pull the top palm rest free. Remove the screw on the far top right hand side. Then carefully pry the bezel free. Pull the final cable connections from their sockets on the motherboard. Undo the top-left screw, then gently lift the palm rest towards you starting back to front(in orange).
  • You will need to remove the bezel under the LCD hinge to finally pull the top palm rest free.
  • Remove the screw on the far top right hand side. Then carefully pry the bezel free.
  • Pull the final cable connections from their sockets on the motherboard. Undo the top-left screw, then gently lift the palm rest towards you starting back to front(in orange).
Hier Übersetzung einfügen
