Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2
Loosen the two captive screws on the right hand side of the hard drive cover. The screws will remain attached to the cover. Remove the hard drive by lifting it up vertically on the right hand side. There is usually a plastic pull tab to help. If this does not work, gently pry it out with a flat head screwdriver. Remove the one screw under the hard drive. This will help release the motherboard for later steps.
  • Loosen the two captive screws on the right hand side of the hard drive cover. The screws will remain attached to the cover.
  • Remove the hard drive by lifting it up vertically on the right hand side. There is usually a plastic pull tab to help. If this does not work, gently pry it out with a flat head screwdriver.
  • Remove the one screw under the hard drive. This will help release the motherboard for later steps.
Hier Übersetzung einfügen
