Zum Hauptinhalt wechseln
Englisch
Deutsch
6. Schritt
Not all work environments are perfectly clean, so subjects may end up with hair, dust, dirt or other imperfections on them. Major offenders should be removed if possible. Spot Healing and Clone Stamp tools are particularly useful for erasing imperfections without greatly affecting textured surfaces like in the pictures shown.
Spot Healing
  • Not all work environments are perfectly clean, so subjects may end up with hair, dust, dirt or other imperfections on them. Major offenders should be removed if possible.
  • Spot Healing and Clone Stamp tools are particularly useful for erasing imperfections without greatly affecting textured surfaces like in the pictures shown.
  • The Spot Healing tool used on this picture takes an imperfection and edits over it using details from the surrounding area. It is a good tool for fixing small blemishes (like the specks in our photo) since any inconsistencies that result from the editing are hardly noticeable.
  • The Clone Stamp tool is similar to the spot healing tool except you manually select what area you will be copying from. This tool is good for larger edits, but may require some extra touching-up to get the correct look.
  • Some imperfections may not be visible when placed into the smaller guide windows, but may be easily seen if the full sized image is viewed. Consider whether or not the imperfection would be visible under the greatest available zoom.
Nicht alle Arbeitsbereiche sind perfekt sauber, so dass sich an den Gegenstände am Ende Haare, Staub, Schmutz oder anderen Unvollkommenheiten befinden können. Besonders störende Dinge sollten nach Möglichkeit entfernt werden.
Spot Healing und Clone Stamp Tools sind besonders nützlich, um Unvollkommenheiten zu löschen, ohne die strukturierten Oberflächen wie in den gezeigten Bildern zu stark zu beeinträchtigen.
Das auf diesem Bild verwendete Spot Healing Tool nimmt eine Unvollkommenheit auf und bearbeitet sie mit Details aus der Umgebung. Es ist ein gutes Werkzeug, um kleine Fehler (wie die Flecken auf unserem Foto) zu beheben, da Unstimmigkeiten, die durch die Bearbeitung entstehen, kaum wahrnehmbar sind.
Das Clone Stamp Tool ähnelt dem Spot Healing Tool, außer dass du manuell auswählst, aus welchem Bereich du kopieren möchtest. Dieses Tool ist gut für größere Bearbeitungen, kann aber einige zusätzliche Nachbesserungen erfordern, um das richtige Aussehen zu erhalten.
Einige Imperfektionen sind möglicherweise nicht sichtbar, wenn sie in den kleineren Führungsfenstern platziert werden, können aber leicht sichtbar sein, wenn das Bild in voller Größe betrachtet wird. Überlege dir, ob die Unvollkommenheit unter dem größten verfügbaren Zoom sichtbar wäre oder nicht.
