Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 2 übersetzen
Schritt 2
If this is the original battery, it might be hold down by VERY strong adhesive on the top, middle and bottom part. Be careful not to damage the battery As pointed in the comments, be careful about the NFC membrane when removing the battery. Use heat to loosen the glue. As pointed in the comments, be careful about the NFC membrane when removing the battery. Use heat to loosen the glue.
Remove the Battery
  • If this is the original battery, it might be hold down by VERY strong adhesive on the top, middle and bottom part. Be careful not to damage the battery
  • As pointed in the comments, be careful about the NFC membrane when removing the battery. Use heat to loosen the glue.
Hier Übersetzung einfügen
