Zum Hauptinhalt wechseln
Englisch
Deutsch
10. Schritt
Place the red wire tip on the positive terminal. Hold the solder strand so that it is touching the terminal and tip, and apply heat with the soldering iron until the two fuse together and produce a small amount of smoke.
  • Place the red wire tip on the positive terminal. Hold the solder strand so that it is touching the terminal and tip, and apply heat with the soldering iron until the two fuse together and produce a small amount of smoke.
  • Repeat the procedure for the black wire tip to the negative terminal.
Hier Übersetzung einfügen
