Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 8 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you. Push the  oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
  • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
  • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
  • Note: Some force may be required to push in the oval buttons open the PC case.
Hier Übersetzung einfügen
