Zum Hauptinhalt wechseln
Englisch
Deutsch
2. Schritt
Measure the approximate length of heat shrink to throughly cover all nearby damage with a single piece of heat shrink. The length of the heat shrink should be longer than the actual length of the damaged or exposed wire.
  • Measure the approximate length of heat shrink to throughly cover all nearby damage with a single piece of heat shrink.
  • The length of the heat shrink should be longer than the actual length of the damaged or exposed wire.
  • Use 3/8" diameter heat shrink. This size diameter is large enough to slide over the charging interface and small enough to secure itself on the wire when heated.
  • Cut the heat shrink to appropriate length using scissors.
Hier Übersetzung einfügen
