Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 3 übersetzen
Step 3
Turn the camera so that the lens is facing you. Do not pull the front panel off without removing the ribbon cable first. Slowly lift the front panel from the camera.
  • Turn the camera so that the lens is facing you.
  • Do not pull the front panel off without removing the ribbon cable first.
  • Slowly lift the front panel from the camera.
  • The ribbon cable is connecting the front panel to the camera. Using the tweezers, gently pull the ribbon cable out of its socket.
  • A spudger may also be used to remove the ribbon cable.
  • Remove the rubber guard that rests on top of the lens.
Hier Übersetzung einfügen
