Englisch
Deutsch
Schritt 2 übersetzen
2. Schritt
Use the chain cutter tool to press the chain pin back through the chain link. If it is difficult to push it back in, the links are not aligned properly. Realign and try again if this is the case. Caution: Reusing pins in chains can cause the chain to fail.  This is because the pins are press fit into link.  Using a new pin when assembling a chain is recommend for long term use.
  • Use the chain cutter tool to press the chain pin back through the chain link. If it is difficult to push it back in, the links are not aligned properly. Realign and try again if this is the case.
  • Caution: Reusing pins in chains can cause the chain to fail. This is because the pins are press fit into link. Using a new pin when assembling a chain is recommend for long term use.
Hier Übersetzung einfügen
