Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 2
Becoming more common on mains chargers, most of the design is fastened together during the moulding process. There is only a single screw (Torx T9 M2.5 x 2.75mm) in the entire product.
  • Becoming more common on mains chargers, most of the design is fastened together during the moulding process. There is only a single screw (Torx T9 M2.5 x 2.75mm) in the entire product.
  • You could possibly pry this open, but you would likely make a big mess. Instead this has been cut in two using a fine bladed coping saw.
  • This was cut 1mm behind the USB port entrance.
  • Inside we can see the design has been split into two halves.
  • All of the electronics are on a single PCB on the left.
  • All of the mechanism and high voltage contacts are on the right hidden under plastic hood.
Hier Übersetzung einfügen
