Zum Hauptinhalt wechseln
Englisch
Deutsch
5. Schritt
With the three bolts remove the air filter housing can simply removed. This gives full access to the power steering gear and hoses. New line. Use a 16mm x 18mm flare nut wrench. It will be safer then a open end wrench since it provides a better grip. This will prevent any damage to the flare nut on the hose.
  • With the three bolts remove the air filter housing can simply removed. This gives full access to the power steering gear and hoses.
  • New line.
  • Use a 16mm x 18mm flare nut wrench. It will be safer then a open end wrench since it provides a better grip. This will prevent any damage to the flare nut on the hose.
  • Disconnect the hose on the power steering pump by loosing the flare nut in a counter clockwise rotation
Hier Übersetzung einfügen
