Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
These steps are as generic as possible, since most LCD displays use a similar design. However, you will need to think carefully about how to take the display apart so you can put it back together, and have it still work!
  • These steps are as generic as possible, since most LCD displays use a similar design. However, you will need to think carefully about how to take the display apart so you can put it back together, and have it still work!
  • The images are from Repair ViewSonic VX924 LCD Monitor Blinking Green power Button (youtube). You should watch it through once to get an idea for what it's like.
  • First, remove the plastic back of the monitor. The stand/pedestal may be attached by screws, or the back and the stand may all be one unit.
  • Keep the screws you removed with the plastic back. That way they won't get mixed up with the screws you take out of the internal parts.
  • There is also probably some sort of snap-on device molded into the plastic back.
  • In the video, a piece of steel is used. A screwdriver or a piece of strong, flat plastic can also do the job.
  • Snapping the back off should take some strength; however, too much force will permanently damage the plastic.
  • Start with very little force and poke the edges of the back. If one corner moves easily but another corner seems solid, then you may have missed a screw. Gradually increase the force you are using until the snaps come off.
Hier Übersetzung einfügen
