Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Remove the two plastic strips off the bottom of the main Kinect housing using the metal spudger's sharper side. Peel off the two Xbox 360 stickers from the bottom of the case to reveal two hidden screws. Some force may be required to remove the adhesive. Applying heat to the adhesive may make it easier to remove.
  • Remove the two plastic strips off the bottom of the main Kinect housing using the metal spudger's sharper side.
  • Peel off the two Xbox 360 stickers from the bottom of the case to reveal two hidden screws.
  • Some force may be required to remove the adhesive. Applying heat to the adhesive may make it easier to remove.
  • Do not overheat as it may cause damage to the internal components.
Hier Übersetzung einfügen
