Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 5
Use the spudger to remove the heat shield tape and detach the image sensor from the motherboard. Using the T4 Torx toolbit, remove the 4 screws that connect the sensor to the lens. Remove the silver connector of the image sensor from the motherboard using the spudger to pry it off.
  • Use the spudger to remove the heat shield tape and detach the image sensor from the motherboard.
  • Using the T4 Torx toolbit, remove the 4 screws that connect the sensor to the lens.
  • Remove the silver connector of the image sensor from the motherboard using the spudger to pry it off.
Hier Übersetzung einfügen
