Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 7 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
2. Schritt
Use a spudger to pry the modem up from the end nearest the AirPort card to separate its connector from a socket on the logic board. Be sure to pry only against the heat sink or the metal framework.
  • Use a spudger to pry the modem up from the end nearest the AirPort card to separate its connector from a socket on the logic board.
  • Be sure to pry only against the heat sink or the metal framework.
  • Use your hands to seperate the modem from the modem shield.
Hier Übersetzung einfügen
