Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 2
Remove the two 1.5 mm Phillips screws securing the battery connector to the motherboard.
  • Remove the two 1.5 mm Phillips screws securing the battery connector to the motherboard.
  • Use a spudger to pry the battery connector from its socket, being careful to apply pressure only to the connector and not to the socket.
Entferne die beiden 1,5 mm Kreuzschlitz Schrauben, die den Akku an der Hauptplatine befestigen.
[* red] Remove the two 1.5 mm Phillips screws securing the battery connector to the motherboard.
[* black] Use a spudger to pry the battery connector from its socket, being careful to apply pressure only to the connector and not to the socket.
