Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 5
With the tweezers, carefully lift up on the tape covering the electrical strip shown in the picture. Be careful with the tape as it can tear easily. You will have better luck if you pull back the orange Kapton tape rather than the silver electrical strip. Use your fingernail or a spudger to lift the hinged retainer clip on the ZIF connector and slide the cable out.
  • With the tweezers, carefully lift up on the tape covering the electrical strip shown in the picture.
  • Be careful with the tape as it can tear easily. You will have better luck if you pull back the orange Kapton tape rather than the silver electrical strip.
  • Use your fingernail or a spudger to lift the hinged retainer clip on the ZIF connector and slide the cable out.
Ziehe mit der Pinzette vorsichtig den Klebestreifen ab, der das Kabel bedeckt.
Sei mit dem Klebestreifen vorsichtig, er kann leicht reißen.
Verwende einen Plastikspatel, um den ZIF-Stecker zu lösen.
[* black] With the tweezers, carefully lift up on the tape covering the electrical strip shown in the picture.
[* icon_caution] Be careful with the tape,tape as it can tear easily. You will have better luck if you pull back the orange Kapton tape rather than the silver electrical strip.
[* red] Use your fingernail or a spudger to disconnectlift the hinged retainer clip on the ZIF connectorconnector and slide the cable out.
