Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 7
Remove the dual LED flash cover. This is held on with a small amount of adhesive. Be careful here: the flash cover may be glued to the antenna cable(s) below. Apply a small amount of heat here to soften the adhesive before removal. Use a pair of tweezers to disconnect the two antenna cables near the camera. Note that some models of this phone will have only one antenna cable at this location. Use a pair of tweezers to disconnect the antenna cable near the bottom of the phone.
  • Remove the dual LED flash cover. This is held on with a small amount of adhesive. Be careful here: the flash cover may be glued to the antenna cable(s) below. Apply a small amount of heat here to soften the adhesive before removal.
  • Use a pair of tweezers to disconnect the two antenna cables near the camera. Note that some models of this phone will have only one antenna cable at this location.
  • Use a pair of tweezers to disconnect the antenna cable near the bottom of the phone.
Entferne die Abdeckung der beiden LEDs.
Entferne mit einer Pinzette die beiden Antennenkabel.
[* black] Remove the dual LED flash cover. This is held on with a small amount of adhesive. Be careful here: the flash cover may be glued to the antenna cable(s) below. Apply a small amount of heat here to soften the adhesive before removal.
[* red] Use a pair of tweezers to disconnect the two antenna cablescables near the camera. Note that some models of this phone will have only one antenna cable at this location.
[* orange] Use a pair of tweezers to disconnect the antenna cable near the bottom of the phone
