Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 9 übersetzen
Schritt 9
Use a pair of tweezers to gently lift the vibrator out of its crevace. It is held in only with friction, no adhesive or screws. Be careful when lifting to avoid damaging the wires connecting it to the motherboard. Use a plastic opening tool or a spudger to gently pry the motherboard out of the case. lift first from the top (near the camera).
  • Use a pair of tweezers to gently lift the vibrator out of its crevace. It is held in only with friction, no adhesive or screws. Be careful when lifting to avoid damaging the wires connecting it to the motherboard.
  • Use a plastic opening tool or a spudger to gently pry the motherboard out of the case. lift first from the top (near the camera).
  • The motherboard is secured with adhesive at the bottom (on the speaker assembly) so you may need to use an iOpener or heat gun to loosen the adhesive. Refer to the iOpener guide for info on this.
Ziehe den Vibrationsmotor mit einer Pinzette behutsam von der Hauptplatine.
Die Hauptplatine hebelst du mit einem Plastikhebel oder per Hand aus dem Gehäuse des Smartphones.
Die Hauptplatine ist mit Klebstoff befestigt, weshalb du einen iOpener oder eine Heißluftpistole benötigst, um die Verklebung zu lösen. Weitere Informationen dazu findest du in der Anleitung des iOpeners.
[* black] Use a pair of tweezers to gently lift the vibrator offout of its crevace. It is held in only with friction, no adhesive or screws. Be careful when lifting to avoid damaging the wires connecting it to the motherboard.
[* black] Use a plastic opening tool or your handsa spudger to gently pry the motherboard out of the case. lift first from the top (near the camera).
[* icon_note] The motherboard is secured with adhesive,adhesive at the bottom (on the speaker assembly) so you may need to use an iOpener or heatgunheat gun to loosen the adhesive. Refer to the [guide|11677|iOpener guide|new_window=true] for info on this.
