Englisch
Deutsch
5. Schritt
Once the back is open you can reach this wire and unplug it from the controller board.  This is a wire that is plugged in and can be removed.  I have seen issues with this being very tight before and you also pull the plug and the connector off the solder leads, so be careful.  Once this speaker wire has been unplugged you can set this case piece out of the way.  (need better photo)
  • Once the back is open you can reach this wire and unplug it from the controller board. This is a wire that is plugged in and can be removed. I have seen issues with this being very tight before and you also pull the plug and the connector off the solder leads, so be careful. Once this speaker wire has been unplugged you can set this case piece out of the way. (need better photo)
Hier Übersetzung einfügen
