Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 6 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
2. Schritt
Support the display with one hand as you remove the remaining T8 screws.
  • Support the display with one hand as you remove the remaining T8 screws.
  • Remove the upper two full thread 10 mm T8 Torx screws from each side of the display, then the two lower shanked 13 mm screws (four screws total).
  • When replacing the display, make sure that the correct screw pins down the ground loop from the display data cable.
  • Disconnect the two antenna cables from the airport/bluetooth card (shown in yellow circles), as well as the display cable (wide connector right hand upper corner) and the cable on top left corner of the logic board (shown in blue square).
Hier Übersetzung einfügen
