Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 11 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
8. Schritt
Use an iPod opening tool to slightly lift the top edge of the Wi-Fi antenna away from the logic board. Use the tip of a spudger to pull the Wi-Fi retaining clips away from the inner frame. Remove the Wi-Fi antenna from the iPhone. Make sure you don't lose the metal clips on the top of the cover where the 4.8mm screw attaches or the 4.8mm screw. That's the primary reason for abnormal Wi-Fi performance after the reassembly.
  • Use an iPod opening tool to slightly lift the top edge of the Wi-Fi antenna away from the logic board.
  • Use the tip of a spudger to pull the Wi-Fi retaining clips away from the inner frame.
  • Remove the Wi-Fi antenna from the iPhone. Make sure you don't lose the metal clips on the top of the cover where the 4.8mm screw attaches or the 4.8mm screw. That's the primary reason for abnormal Wi-Fi performance after the reassembly.
  • Before reassembly, be sure to clean all metal-to-metal contact points on the connector cover with a de-greaser such as Windex. The oils on your fingers have the potential to cause wireless interference issues. Do not clean the connectors themselves with Windex.
Verwende ein iPod Opening Tool, um die Oberseite der Wi-Fi Antenne vom Logic Board wegzuheben.
Ziehe mit einem Spudger die Wi-Fi Rückhalte-Clips vom inneren Rahmen weg.
Entferne die Wi-Fi Antenne vom iPhone. Stelle sicher, dass du die Metallclips oben auf der Abdeckung, wo die 4,8mm Schrauben sitzt, nicht verlierst, oder die 4,8 mm Schraube selbst. Probleme mit dieser Schraube sind der häufigste Grund für eine schlechte Wi-Fi Leistung nach dem Wiederzusammenbau.
Before reassembly, be sure to clean all metal-to-metal contact points on the dock connector cable cover with a de-greaser such as windex. The oils on your fingers have the potential to cause wireless interference issues. Reinige nicht die Anschlüsse selbst mit dem Entfetter.
