Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
To remove the Gear 2 Neo's watch band, start by locating the small metal levers on either end of the band. Using your finger, push downward on the lever to release the band locking mechanism. Note: If you have especially short fingernails, it may be easier to use a spudger to depress the levers.
Removing the Watch Band
  • To remove the Gear 2 Neo's watch band, start by locating the small metal levers on either end of the band.
  • Using your finger, push downward on the lever to release the band locking mechanism.
  • Note: If you have especially short fingernails, it may be easier to use a spudger to depress the levers.
  • Continue to hold the lever down and pull the end of the band away from the watch to completely detach it.
  • Repeat this process for the other side of the band to fully release it.
Hier Übersetzung einfügen
