Zum Hauptinhalt wechseln
Fix Your Stuff
Right to Repair
Parts & Tools
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 8 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 5
Lift the camera-side end of the motherboard to separate it from the display frame. You may need to move some of the ribbon cables out of the way while you lift the motherboard. If the board is hard to lift, check that it is fully disconnected and not caught on any ribbon cables.
  • Lift the camera-side end of the motherboard to separate it from the display frame.
  • You may need to move some of the ribbon cables out of the way while you lift the motherboard. If the board is hard to lift, check that it is fully disconnected and not caught on any ribbon cables.
  • Do not fully remove the motherboard yet—it is still attached to the daughterboard via a ribbon cable on the underside of the motherboard.
Hebe das Motherboard am Ende bei der Kamera, um des vom Displayrahmen zu trennen.
Entferne das Motherboard noch nicht vollständig — es ist noch mit einem Flachbandkabel an der Unterseite des Motherboards befestigt.
[* black] Lift the camera-side end of the motherboard to separate it from the display frame.
[* icon_note] You may need to move some of the ribbon cables out of the way while you lift the motherboard. If the board is hard to lift, check that it is fully disconnected and not caught on any ribbon cables.
[* icon_caution] Do '''not''' fully remove the motherboard yet—it is still attached to the daughterboard via a ribbon cable on the underside of the motherboard.
