Zum Hauptinhalt wechseln
Englisch
Deutsch
6. Schritt
Slide a spudger beneath the logic board on the side opposite the battery connector and pry up slightly. Don't lift up too far, because there are still four attached connectors on the bottom of the logic board.
  • Slide a spudger beneath the logic board on the side opposite the battery connector and pry up slightly. Don't lift up too far, because there are still four attached connectors on the bottom of the logic board.
Schiebe einen Spudger gegenüber des Akkusteckers unter das Logic Board und heble es leicht hoch. Hebe es nicht zu weit an, da an der Unterseite des Logic Boards immer noch vier Stecker befestigt sind.
