Englisch
Deutsch
2. Schritt
Use the tip of a spudger to push the sides of the ZIF connector fastener securing the spindle motor ribbon cable directly away from the connector. Disconnect the spindle motor ribbon cable by pulling it straight out of its connector with a pair of tweezers. Disconnect the spindle motor ribbon cable by pulling it straight out of its connector with a pair of tweezers.
  • Use the tip of a spudger to push the sides of the ZIF connector fastener securing the spindle motor ribbon cable directly away from the connector.
  • Disconnect the spindle motor ribbon cable by pulling it straight out of its connector with a pair of tweezers.
Drücke mit der Spudgerspitze auf beiden Seiten des ZIF Verbinders die Feststellklemme am Flachbandkabel zum Spindelmotor heraus.
Löse das Flachbandkabel zum Spindelmotor, indem du es mit der Pinzette gerade aus dem Verbinder herausziehst.
