Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 36 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 8 übersetzen
Schritt 8
While holding up the upper case (from the bottom or the top), use a spudger to pry up the orange trackpad and keyboard cable from its connector.
  • While holding up the upper case (from the bottom or the top), use a spudger to pry up the orange trackpad and keyboard cable from its connector.
  • Take care to pry between the black socket and the white connector. You might have to pry on both sides for it to release properly.
  • Do not pry from the bottom or the top, but from the sides.
  • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
Hier Übersetzung einfügen
