Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 12 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
2. Schritt
In the following steps you must pull the antenna cable between the DS Lite game cartridge reader and motherboard.  Pull slowly and stop when you feel resistance to avoid damaging the cable or motherboard. Position the antenna cable with its connector facing up and away from the motherboard using a spudger to hold it down lightly in the gap between chips on the motherboard. Slowly and carefully pull the antenna cable until the cable connector is under the DS Lite game cartridge reader.
  • In the following steps you must pull the antenna cable between the DS Lite game cartridge reader and motherboard. Pull slowly and stop when you feel resistance to avoid damaging the cable or motherboard.
  • Position the antenna cable with its connector facing up and away from the motherboard using a spudger to hold it down lightly in the gap between chips on the motherboard.
  • Slowly and carefully pull the antenna cable until the cable connector is under the DS Lite game cartridge reader.
  • Continue pulling the cable until the cable connector comes out from under the game cartridge reader on the right side.
  • When reassembling and attempting to feed the antenna cable back under the game cartridge reader, the cable may kink or become difficult to feed through. If so, try feeding a piece of thread through first; then, tie the thread to one end of the cable connector and pull it through, guiding it past any obstructions.
Im nachfolgenden Schritt musst du das Antennenkabel zwischen dem Cartridge-Leser und der Platine heraus ziehen. Sei dabei sehr sorgfältig, wenn du zu starken Widerstand spürst musst du anhalten um Schäden zu vermeiden.
Lege das Antennenkabel mit dem Verbinder nach oben zeigend weg von der Platine und halte es mit dem Spudger nach unten in den Spalt zwischen einigen Bauteilen auf der Platine.
Ziehe ganz vorsichtig am Kabel bis der Verbinder unter dem Cartridge-Leser ist.
Ziehe weiter, bis der Verbinder unter dem Leser heraus kommt.
Beim Zusammenbau wird sich das Kabel möglicherweise verbiegen und ist nicht leicht unter dem Leser entlang zu schieben. Wenn das so ist, dann fädle einen Faden erst unten entlang, binde ihn am Verbinder fest und ziehe ihn damit an den Hindernissen vorbei.
