Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 5
Do not completely remove the main circuit board from the camera. A soldered ribbon cable still attaches the board to the camera. Complete removal would break the soldering points. In a hinge-like motion, gently lift the bottom of the main circuit board, which is the side without the soldering points.
  • Do not completely remove the main circuit board from the camera. A soldered ribbon cable still attaches the board to the camera. Complete removal would break the soldering points.
  • In a hinge-like motion, gently lift the bottom of the main circuit board, which is the side without the soldering points.
  • Gently detach the white ribbon cable from the underside of the main circuit board.
Hier Übersetzung einfügen
