Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 8
Use the edge of a plastic opening tool to peel the dock connector and its cable off the black plastic case of the iPhone. If you are replacing the dock connector with a new part, make sure to transfer the rubber casing around the microphone. You can do this using a spudger.
  • Use the edge of a plastic opening tool to peel the dock connector and its cable off the black plastic case of the iPhone.
  • If you are replacing the dock connector with a new part, make sure to transfer the rubber casing around the microphone. You can do this using a spudger.
Hier Übersetzung einfügen
