Englisch
Deutsch
2. Schritt
Remove the tape that runs along the length of the battery. Lift the retaining flaps of the ZIF connectors on each side of the battery connector. Remove the two ribbon cables that lie across the width of the battery and are connected to the motherboard. Place your finger underneath the ribbon cable and gently lift the cable upwards and off.
  • Remove the tape that runs along the length of the battery.
  • Lift the retaining flaps of the ZIF connectors on each side of the battery connector.
  • Remove the two ribbon cables that lie across the width of the battery and are connected to the motherboard. Place your finger underneath the ribbon cable and gently lift the cable upwards and off.
Entferne den Klebestreifen, der längs des Akkus verläuft.
Öffne die Klappen der ZIF-Kontakte auf beiden Seiten des Akkuanschlusses.
Entferne die zwei Flachbandkabel, die über dem Akku verlaufen und mit der Hauptplatine verbunden sind, indem du mit den Fingern die Kabel von unten anhebst.
