Englisch
Deutsch
4. Schritt
Use the flat end of a spudger to disconnect the display data cable connector. When reassembling your phone, the display data cable may pop off its connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector. When reassembling your phone, the display data cable may pop off its connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector.
  • Use the flat end of a spudger to disconnect the display data cable connector.
  • When reassembling your phone, the display data cable may pop off its connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector.
Verwende das flache Ende eines Spudgers, um den Display Datenkabelstecker zu trennen.
Wenn du dein Mobiltelefon wieder zusammenbaust, springt das Datenkabel möglicherweise vom Stecker ab. Dies kann in weißen Linien oder einem schwarzen Bildschirm resultieren, wenn du dein Mobiltelefon wieder anmachst.
Wenn das passiert, schließe das Kabel einfach wieder an und trenne am besten kurz den Akkustecker. Schließe den Akkustecker dann wieder an und starte dein Mobiltelefon neu.
