Zum Hauptinhalt wechseln
Englisch
Deutsch
Step 5
Set the load size. You can adjust this to whatever size load of laundry you are doing. Just be sure not to overload the washer, which not only is bad for your machine but creates additional wear on your clothes. Not sure what overloaded is? Check the guidelines in your user manual. A good rule of thumb is to only fill your washer 2/3 full.
  • Set the load size.
  • You can adjust this to whatever size load of laundry you are doing. Just be sure not to overload the washer, which not only is bad for your machine but creates additional wear on your clothes.
  • Not sure what overloaded is? Check the guidelines in your user manual. A good rule of thumb is to only fill your washer 2/3 full.
  • Set the water temperature on the washing machine to cold/cold.
  • Hot water can damage the fibers of your jeans and cause them to shrink. Never wash your jeans in hot water.
  • Start the washing machine on a gentle or normal wash cycle.
Je nachdem wie voll Ihre Waschmaschine jetzt ist, stellen Sie die richtige Funktion ein.
Machen Sie die Maschine nicht zu voll, dadurch kann die Kleidung beschädigt werden.
Stellen Sie die niedrigste Temperatur ein.
Zu heißes Wasser kann die Jeans beschädigen und sie kann eingehen/schrumpfen
Fügen Sie Waschmittel hinzu und starten Sie die Waschmaschine.
