Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Remove the two 2.0 mm Phillips screws securing the power button bracket to the outer case. Slightly pull the power button cable bracket away from the outer case. If the power button happens to accidentally fall out, take note of the correct orientation. The metal loop should be facing downwards and the outward edges should be on top.
  • Remove the two 2.0 mm Phillips screws securing the power button bracket to the outer case.
  • Slightly pull the power button cable bracket away from the outer case.
  • If the power button happens to accidentally fall out, take note of the correct orientation. The metal loop should be facing downwards and the outward edges should be on top.
Hier Übersetzung einfügen
