Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 11
Use the edge of a plastic opening tool to gently pry up the display assembly around its perimeter. Press gently on the home button to push it through the display and make sure it stays behind as the display separates from the iPhone. Otherwise, the home button cable may tear. De-route the digitizer and LCD cables through the steel inner frame.
  • Use the edge of a plastic opening tool to gently pry up the display assembly around its perimeter.
  • Press gently on the home button to push it through the display and make sure it stays behind as the display separates from the iPhone. Otherwise, the home button cable may tear.
  • De-route the digitizer and LCD cables through the steel inner frame.
  • When reinstalling the display, carefully straighten the digitizer and LCD data cables, and feed them through the slot cut in the steel frame. This photo shows the display assembly being installed incorrectly, with a fold in the digitizer cable.
  • When the front panel has been correctly installed, both the LCD and digitizer cables should be immediately next to one another and should be the same length, as shown in the second photo.
  • If the digitizer cable has been installed incorrectly, it will not reach its socket on the logic board. Do not attempt to pull it through by force, or it will tear. Remove the display assembly, straighten the cable, and feed it through to its full length, as shown.
  • During reassembly, do not touch the metallic area at the base of the LCD data cable, as this can cause problems with the LCD. If you do touch it accidentally, clean it gently with an alcohol wipe before continuing.
Benutze die Kante eines Plastiköffnungswerkzeugs, um die Displayeinheit ringsherum hochzuhebeln.
Fädle die Kabel von Touchscreen und LCD durch den Stahl-Innenrahmen.
Glätte die Kabel von Touchscreen und LCD beim Wiedereinbau des Displays sorgfältig und führe sie durch den Schlitz im Stahlrahmen. Dieses Foto zeigt eine falsch eingesetzte Displayeinheit, da sich im Touchscreenkabel eine Falte befindet.
Wenn das Frontpanel korrekt eingesetzt wurde, sollten die Kabel von Touchscreen und LCD dicht beieinander liegen und die gleiche Länge haben, so wie es auf dem zweiten Foto zu sehen ist.
Wenn das Touchscreen-Kabel falsch eingesetzt wurde, ist es zu kurz, um seinen Anschluss auf dem Logic Board zu erreichen. Versuche nicht, es gewaltsam durchzuziehen, es wird sonst reißen. Entferne die Displayeinheit, glätte das Kabel und führe es, wie gezeigt, ganz durch den Schlitz.
Berühre beim Wiederzusammenbau nicht den metallenen Bereich unten am LCD Datenkabel, da dies zu Problemen mit dem LCD führen kann. Falls du ihn versehentlich berührt hast, reinige ihn vorsichtig mit einem Alkoholwischtuch, bevor du weitermachst.
[* black] Use the edge of a plastic opening tool to gently pry up the display assembly around its perimeter.
[* icon_caution] Press gently on the home button to push it through the display and make sure it stays behind as the display separates from the iPhone. Otherwise, the [guide|5062|home button cable|stepid=22825|new_window=true] may tear.
[* black] De-route the digitizer and LCD cables through the steel inner frame.
[* icon_reminder] When reinstalling the display, carefully straighten the digitizer and LCD data cables, and feed them through the slot cut in the steel frame. [https://d3nevzfk7ii3be.cloudfront.net/igi/pOnFkdECiyCBgkjU|This photo|new_window=true] shows the display assembly being installed '''incorrectly''', with a fold in the digitizer cable.
[* black] When the front panel has been correctly installed, both the LCD and digitizer cables should be immediately next to one another and should be the same length, as shown in the second photo.
[* icon_caution] If the digitizer cable has been installed incorrectly, it will not reach its socket on the logic board. '''Do not''' attempt to pull it through by force, or it will tear. Remove the display assembly, straighten the cable, and feed it through to its full length, as shown.
[* red] During reassembly, do not touch the metallic area at the base of the LCD data cable, as this can cause problems with the LCD. If you do touch it accidentally, clean it gently with an alcohol wipe before continuing.
