Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 6 übersetzen
6. Schritt
There are four slots that are located along the border that can be used to remove the strip that is glued to the side. Wedge the tweezers in each slot to carefully remove the strip. Wedge the tweezers in each slot to carefully remove the strip.
  • There are four slots that are located along the border that can be used to remove the strip that is glued to the side.
  • Wedge the tweezers in each slot to carefully remove the strip.
Es gibt vier Vertiefungen am Rand, die du benutzen kannst um den Streifen der an der Seite festgeklebt ist, zu lösen.
Setze die Pinzette in jede der Vertiefungen um sorgfältig den Streifen zu entfernen.
