Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Remove the soft, protective, outer covering. Use a heat gun (or a hair-dryer) to heat the main unit of the Plantronics Voyager Legend.  This will loosen the adhesive that bonds the covering to the housing. Use the pointed end of a small, metal spudger to begin separating the covering from the housing.
  • Remove the soft, protective, outer covering.
  • Use a heat gun (or a hair-dryer) to heat the main unit of the Plantronics Voyager Legend. This will loosen the adhesive that bonds the covering to the housing.
  • Use the pointed end of a small, metal spudger to begin separating the covering from the housing.
  • Use the rounded, dull end of the spudger to gently detach the rest of the covering.
  • It may be necessary to reheat the unit to keep the adhesive soft enough to remove the covering without damaging it.
Hier Übersetzung einfügen
